6 members (32Fordpuchoptop, Youngin' Tut 59, treegrower, Gray_Ghost, Wickedbass, WICruiser), 66 guests, and 3 robots.
Topics128,076
Posts1,055,922
Members48,430
#1188653 10/29/2016 2:01 AM
I would like to install a battery tray that would accommodate a grp27 battery instead of the grp24 (on TF truck). Any ideas or does someone sell an aftermarket battery tray that will fit a larger battery.
Admin for Turbobuick.com
87 GN, and new toy: 1955 Chevy 3200 pickup, soon to have: 383, Cola crank, Childs/Albert 6 inch rods, Brownfield heads, 10:1 KB hypers, CompCam 284 Extreme Energy, Tilton Plate transmission realignment and built Turbo400.
Big Bolt Forum Moderator
I have thought the same thing, was going to make one but never got around to it!
Mike
If your not comfortable making one yourself, I'm sure there are several sheet metal fabricating shops around Sacramento. Take your measurements to one of them and have it made to fit. They can do the mounting holes/tabs and it will be a direct bolt in.
Crusing in the Passing Lane
One might find a factory one the size you want in other models of same mfgr., or some other mfgr.
Ed
Any particular reason you want a group 27 over a 24? Most 24s will easily outperform a 27 in CCA and reserve, and weigh lees as well. Or better yet, many 34/78 combination group batteries outperform both, and are only a bit shorter in height than the 24 and have even more of a reduced weight.
Bill Burmeister
I was hoping to use a Delco 1000cca group 27 battery to power my truck. But I noticed Bosch sells a Group 48 and a Group 78DT (side and top terminals), in AGM that will fill my needs. Both are close to or over 800cca. So yes, that is a great suggestion.
