4 members (Erniegp, Rusty Rod, Rich'sToys, dt235sd), 86 guests, and 3 robots.
Topics128,054
Posts1,055,780
#1188554 10/28/2016 2:16 AM
I finally started my 56. I drove it around the place for a bit. When it is in neutral it makes a loud grinding noise. I'm not sure, but I don't think that would be the throughout barring. The noise quits when I push in the clutch and when its in gear.
1956 Chevy 3600
“Maynard”
In the DITY Gallery
More pictures on Flickr
Bart #1188568 10/28/2016 3:23 AM
That sounds like an input shaft bearing or cluster gear needle bearings. Does the noise get quieter in high gear? If so, you have cluster gear needle bearing problems.
Bart #1188581 10/28/2016 4:05 AM
It only makes the sound in Neutral.
1956 Chevy 3600
“Maynard”
In the DITY Gallery
Bart #1188596 10/28/2016 12:22 PM
Do you have oil in it?
Tommy
59 apache 1/2t
261 short stepside
Bart #1188638 10/29/2016 12:18 AM
Yes, it has oil.
1956 Chevy 3600
“Maynard”
In the DITY Gallery
