4 members (Wayne67vert, Phak1, Peggy M, WICruiser), 127 guests, and 4 robots.
Topics128,111
Posts1,056,243
Members48,437
#1188555 10/28/2016 2:17 AM
When I bought my 51 GMC it came without keys. I ordered a new AC Delco ignition tumbler and key from Rock Auto and it came in this afternoon. I read all the posts on replacing the switch - you either need the old key or a locksmith. Just for kicks, I put the new key in the door and it worked, crossed my fingers, put it in the ignition and it worked there, too. Kind of surprised me that both worked because the door is off a pre-51 truck. My lucky day...
NoJunker #1188563 10/28/2016 2:58 AM
I have run into that before. I have also not run into that before. Maybe they only made a few different lock tumbler sequences. I have also had ignitions which could be turned on with a screwdriver, so who knows?
NoJunker #1188584 10/28/2016 4:30 AM
Big Bolt Forum Moderator
I would probably use the new ignition switch or at least replace the cylinder so it is all new and not worn inside at all... that is lucky though, saves a lot of $$ not having to get anything re-keyed!
Mike
69Cuda #1188754 10/29/2016 11:19 PM
I put the new one in today -- love weekends.
