2 members (Gdads51, 1 invisible), 118 guests, and 8 robots.
Topics128,088
Posts1,056,124
Members48,435
#1188240 10/26/2016 12:23 AM
Hi I have a 1967 c 50. 327 motor. Now when I take off the oil filler cap,the rpm goes up. Then replace the oil filler cap,the rpm drops why? Now there is no vent on valve covers.
crockbuyer #1188244 10/26/2016 12:36 AM
does this make sense................basically your creating a vacuum leak thru the intake that vents the crankcase and oil tank
Redryder pix
My Hotrod
crockbuyer #1188245 10/26/2016 12:37 AM
Is there a PCV valve installed? If so, you need a vented oil fill cap or a set of valve covers with a grommet for a vent pipe connected to the "clean" side of the air filter. Without a vent, the PCV cannot work properly.
