| | | Forums66 Topics128,214 Posts1,057,486 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | What is the best tool to inflate, A stored Non-running Vehicle, Tires? There is No AC Electricity at Storage facility. Any ideas.
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Those little air compressors that plug into a cigarette lighter work pretty good if you can get close enough. I had one by Coleman that lasted for years in both boat and cars, it worked great. | | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | I also picked up one of those portable tanks at HF(or Northern, etc.) that I hook up to the compressor with one of those clipon inflators and let it run until compressor shuts off (ie tank is full). I can get about 15 psi in each tire which allows me to pull it up on a trailer. You could supplement with one of those little compressors Brad mentions....they have pretty slow fill rates but the portable tank will speed things up a bit.
Allen Yeah, well, that's just like, you know , your opinion, man - The Dude
1948 Chevy 3600 - goal Original restoration, Current Stage 1 - Disassembly and getting body in primer 1954 GMC 3100 goal Hot Rod, Current Stage 1 - Get body in primer 1931 Ford Model A 5 window Coupe - Old Skool Hot Rod 1945 Ford 2N Tractor - Runs great 1964 Ford 2000 Tractor - Use it every week 1974 Stingray Corvette
| | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | When using a Portable Air Tank like THESE How long does a full tank of air last? An example would be: The Portable Air Tank can handle a maximum 135 PSI of pressure. You start out with 135 PSI of pressure in the tank. A tire has 10 PSI in it, and you want to fill that tire to 30 PSI. After you add 20 PSI into the tire, how much air or air pressure is left in the Portable Air Tank? Are you gaining anything between using a 5 gallon or a 10 gallon Tank? They both can handle the same maximum 135 PSI of pressure. | | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | You'll only need enough air to get it rolling to an air source.
Sometimes, a lug wrench, jack and some jack stands will work. | | | | | Joined: May 2015 Posts: 11,188 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,188 | When using a Portable Air Tank like THESE How long does a full tank of air last? An example would be: The Portable Air Tank can handle a maximum 135 PSI of pressure. You start out with 135 PSI of pressure in the tank. A tire has 10 PSI in it, and you want to fill that tire to 30 PSI. After you add 20 PSI into the tire, how much air or air pressure is left in the Portable Air Tank? Are you gaining anything between using a 5 gallon or a 10 gallon Tank? They both can handle the same maximum 135 PSI of pressure. That kind of question can give even engineers a headache.  There are really too many variables to give a definite answer. Compressed air is weird stuff (because air is compressible). How much volume is in the tires? What's the initial pressure in them? If they're flat, what's the difference in volume between flat and round? etc. etc. ... Here's some info that I dug up on the web that may help you figure it out. clickIt may just be easier to get the biggest tank and try it to see what it will do. If it doesn't work like you expect, trade in the tank for a bigger one.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Aug 2001 Posts: 3,619 Moderator | | Moderator Joined: Aug 2001 Posts: 3,619 | Generator and a small air compressor in the back of your tow vehicle. If the truck is not close to home, do it right the first time. It will save you some trips to air up the portable tank. I also take a floor jack and a X lug wrench just in case a tire will not hold air.
For a stored vehicle and the tires will hold air. The 12 volt pumps work good, but take some time to get a rise. Make up a 12 volt extension cord if need be.
1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Have a truck with air brakes? Drive it over and use the engine driven compressor and a hose to fill up the tires. Otherwise removing wheels or a portable tank sounds easiest/cheapest. Or something like this... in one form or another has been around for about 100 years http://www.aerostich.com/engineair-power-pump.html | | | | | Joined: Jan 2013 Posts: 1,084 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,084 | I've got the 10 gal version, and all four tires on my 1/2 ton trucks are usually flat when I need to move them. I usually get about 15 psi in all 4 on one tank fill, so would guess about 1/2 that with the smaller tank. Alternatively, as Don says, I'm looking for a good excuse to buy one of those portable Honda generators...and with a small portable pancake compressor that would power a nail gun, you could make quick work of it.
| | | | | Joined: May 2015 Posts: 11,188 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,188 | Those things actually work pretty well. I've used one on my dad's 48 GMC shop truck to pressurize a long gas line for testing purposes. It was about 1/2 mile long, and it made quick work of getting it up to test pressure. Unfortunately I can't use that in the scenario to air up tires on a non-running vehicle unless I borrow a gasser, as my daily driver is a diesel. If it had spark plug holes, it would probably blow it right out.  I like the pancake compressor and generator idea. Always looking for an excuse to buy new tools.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | I think I will try one of those portable air tanks. I have to say I have never seen the Engineair Power Pump that uses a engine cylinder to pump air. I would like to see a video of it in action.
Thanks to all you guys for the ideas! | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I think I will opt out for one of those portable air tanks. I have to say I have never seen the Engineair Power Pump that uses a engine cylinder to pump air. I would like to see a video of it in action.
Thanks to all you guys for the ideas! Screw the 3/8 threaded end of your air chuck/adaptor into the spark plug hole of your choice and crank the engine...
| | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | There are several of those spark plug tire pumps on Ebay right now. I've used one at times, and they work pretty well. They don't use the intake mixture to inflate the tire- - - -there's a small rubber bladder that gets squeezed and released by compression pressure and fresh air gets pumped into the tire. It's noisy, but it works. Jerry
