2 members (Cosmo, Gdads51),
145
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,056 Posts1,055,798 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 124 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 124 | The two brake shoes on my truck are of different lengths. You can put them on either way. Does the long one go towards the front of the truck or does the short one go to the front? I don't remember how I installed them the last time but I just guessed at it. I figure that they will work the best if I do it right. Thanks a lot, Gene
Gene 1959 Apache
| | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | The short lining goes towards the front.
| | | | | Joined: Apr 2012 Posts: 124 Shop Shark | | Shop Shark Joined: Apr 2012 Posts: 124 | I appreciate the info Dusty. I don't know how much difference it will make but the brakes on my truck need all the help they can get. I will write that down in my manual so I will be sure to get it right from now on. Thanks again, Gene
Gene 1959 Apache
| | | | | Joined: Feb 2004 Posts: 29,773 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,773 | The Bendix brake system uses "servo" action, where the forward rotation of the wheel pushes the brake shoe assembly toward the rear of the drum. The front (primary) shoe is shorter because most of the braking action is done by the rear shoe through the servo action. Jerry
