5 members (Peggy M, Hotrod Lincoln, Otto Skorzeny, Ponchogl, msmall), 45 guests, and 3 robots.
Topics128,057
Posts1,055,816
#1188023 10/24/2016 3:12 AM
The two brake shoes on my truck are of different lengths. You can put them on either way. Does the long one go towards the front of the truck or does the short one go to the front? I don't remember how I installed them the last time but I just guessed at it. I figure that they will work the best if I do it right.
Thanks a lot,
Gene
Gene
1959 Apache
The short lining goes towards the front.
I appreciate the info Dusty. I don't know how much difference it will make but the brakes on my truck need all the help they can get. I will write that down in my manual so I will be sure to get it right from now on.
Thanks again,
Gene
Gene
1959 Apache
H Online: Content
The Bendix brake system uses "servo" action, where the forward rotation of the wheel pushes the brake shoe assembly toward the rear of the drum. The front (primary) shoe is shorter because most of the braking action is done by the rear shoe through the servo action.
