5 members (J Lucas, Lugnutz, Otto Skorzeny, Steelonsteel, Rich'sToys), 94 guests, and 2 robots.
Topics128,211
Posts1,057,472
Members48,473
Can anyone give me the part numbers for replacement taper roller bearings for the front axle of my 6400 big bolt? I would like to replace the ball bearing type bearings.
Dale Berg
When did a 2 ton go from barrel rollers to ball bearing?
I stand corrected, they are barrel rollers.
Hyatt A11035 and 11035Z
and
Hyatt A11424 and 11424Z
Is there a replacement taper bearing available?
Dale Berg
The Hyatt came as an assembly KA11035Z which can be replaced with a 15579A and 15522A Timken
The Hyatt KA11424Z assembly can be replaced with a 17888 and 17830 Timken. Any bearing distributor with the old conversion books should be able to make the conversion. The above cup and cone numbers are still good Timken numbers.
Thank You!!
Dale Berg
Thanks for providing the part numbers, I was beginning to think my 51 2 ton project was going to be stopped due to bad wheel bearing races.
I just got my adapters made to mount 15" rotors on the front.
Gillyatt
1951 2 ton Chevy with Gain dump bed
Berg Design Not understanding why you would want to change out bearings that have worked for over 70 years. If serviced and adjusted are tough as nails !!
Races were scored and some of the bearing got hot.
Gillyatt
Gilyatt Overheated bearings if they had lube usually means too tight. Big bearings need some slack,always adjust,drive it a little,FEEL your hubs should be barely warm ( from brake heat) usually. When driving should be able to barely feel slack in the front wheel bearings. Then when you stop feel all the hubs,if a warm one probably too tight, back off till all run barely warm.
Hello Gilyatt! I also have a 1951 6400 that I want to mount front disc brakes on. Where did you get rotors and calipers for your truck? Thanks, Ron Ellis
Big Bolt Forum Co-moderator
Drblues, you might want to check out the first thread on this forum.
1948 Chevy 2-Ton
Crusing in the Passing Lane
Disc brake hubs/spindles from ‘99 to ‘01 +- P-3500HD tie rod b3hind axle will fit with minor king pin mods without tires sticking out past fenders.
Ed
Parts are from a 1990 International. Had custom brackets made to install the caliper mounts, custom hats bolt to the stock hubs, had the 15 rotors machined to mount to the hats. Still have to run the brake lines, install master cylinder and booster.
Rear was simple, just bolted in the International axle and modified driveshaft.
Caliper mount
Caliper adapter
Gillyatt
