1 members (1 invisible),
69
Mod | | | Forums66 Topics128,081 Posts1,056,319 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2016 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2016 Posts: 34 | After 3 months and 300 miles on my newest toy,a '52 4400 with only 22,000 miles, I lost 5 qts. of oil. I changed the valve cover, side push rod cover and oil pan gaskets and still had the notirous oil leak come back. I broke out a black light and multiply attempts kept fighting that driveway killer leaks. The light showed the same side of the oil pan leaking. The STOVEBOLTS that held the oil pan kept backing off. I changed the screws to longer allen caps with flat and lock washers. That cut the leak to almost to nothing. But a drip came back. Bing go the black light found the fuel pump leaked. It was tightened and the last little leak was gone . I hope this helps any one with the same issue. Thank God it was not the rear main. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You should point out that to get the black light to show leaks you need to add UV leak detection dye to the oil. | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Thanks for sharing. Jeffrey | | | | | Joined: Aug 2016 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2016 Posts: 34 | for info sake most conventional oils and fuels have a phosphorus element in them, no additional dyes needed, just uv blacklight flashlight in the dark. | | |
