2 members (Stewart2, 1 invisible), 58 guests, and 7 robots.
Topics128,014
Posts1,055,324
Members48,419
#1187812 10/22/2016 7:11 PM
Does anyone know what the thread size is on the zerks for the shackle pins? Really I just need to know if it's NPT or not because my hardware store has both and I didn't know which to get.
Liquidated my projects
Now looking for a decent '47-'55.1 3100, 3600, or 3800
NPT and what is the other one?
The only thread difference I know is that some have a taper and some the threads are straight though the both of them have the same thread per inch.
So either one should fit but the straight thread one will not screw in as deep if the female hole was tapped NPT. Jeffrey
The fittings with the small-diameter threads are 1/4"-28 thread, same as 1/4" UNF or SAE bolts. The bigger ones have a tapered thread, 1/8" NPT pipe threads. Most of the fittings found on tie rods, ball joints, etc. are 1/4-28 and install with a 5/16" hex wrench or socket.
Riding in the Passing Lane
The king pins & shackle pins use the 1/8 in. pipe thread.
1972 Chevy c10 Cheyenne Super
Thanks guys, that's what I needed
Yep, 1/8" NPT
