0 members (), 91 guests, and 4 robots.
Topics128,024
Posts1,055,393
Members48,422
#1187656 10/20/2016 11:12 PM
In a 1959 235 truck engine with pressurized oiling.
I'm not seeing information in my online searching so far.
And if they're solid, what's the clearance spec? This engine is a fresh rebuild, and if it's solid I'm guessing I should be adjusting them soon.
A VW guy trying his hand at a '59 LB fs. Lots to learn, but it's about the journey.
What is the Engine Serial Number that is pressed into the block to the rear of the distributor - post it here?
If it is a 1959 car 235, it had hydraulic lifters from the factory (but mechanical lifters might have been "swapped in" later).
If it is a 1959 truck 235, it had mechanical lifters from the factory (but hydraulic lifters might have been "swapped in" later).
Here is on-line specification information about 1959 truck engines.
Here is an on-line 1959 car specification manual - it is a very large .pdf file.
By the way, all 235 engines had "pressurized oiling". The better description would be "high-pressure" oiling (as in all 1954 and later 235 engines).
Do you have a 1959 Truck Shop Manual - the valve settings are in it?
Here is a procedure for setting mechanical lifters.
If you have a car 235, the valve setting procedure is described in the 1958 Car Shop Manual.
Reproduction manuals are available; and, original manuals can be found on eBay (and, often via an Internet search).
We're in Michigan visiting family now. I'll get the engine numbers when I'm home and post them.
thanks
BTW, is there any way to tell from a visual inspection? Any difference in the rockers or...?
There may be someone who can tell by adjusting the lifters (after running the engine). It is not so easy/apparent to someone who has not done this on both type engines.
The best way is to pull a lifter and inspect it.
