| | | Forums66 Topics128,139 Posts1,056,455 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | The glass and rubber need replaced on my 53 window vents. Any suggestions who sells the best parts and some good tech tip information? Thanks, Steve | | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | You also have a lot of options. You can buy the entire assembly or just sub components, depending on what is bad and what is good on the current vent assembly. If you are looking to replace everything you are looking at about $300 per side. | | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | | | |
