6 members (1955 1 Series, walter74, artinva, Wally / Montana, SNOYL, Hotrod Lincoln), 59 guests, and 1 robot.
Topics128,078
Posts1,055,936
Members48,430
#118759 12/08/2005 12:24 AM
Wierd question... but:
since cugo asked...
Has anybody painted the fire wall w/ under coat or rhino lining material??
how did it look / turnout??
Can you paint it w/ the engine in?
Jim & Caroline
#118760 12/09/2005 9:54 AM
Well that stuff sprays on thick and with the motor and other stuff in there, it might get a bit messy and be hard to get a consistent coat because of the angles of the gun you were forced to use. However, maybe with a small roller...
#118761 12/11/2005 8:11 PM
I thought about this to to cut down on noise and heat, however I wonder about any concerns with heat and possible fire. This is rubberbased material isn't it? Would this be a concern? I also think it would be a very difficult to do with the engine in.
Steve O
1950 Chevrolet 3100 Deluxe Cab
Gallery Page
Webshots photos
#118762 12/12/2005 5:12 AM
Seems to me it would look strange. I don't think you could possibly do it with the engine in the truck. You would probably just end up with goo all over everything. Once on, it's probably next to impossible to get off.
#118763 12/12/2005 5:59 AM
Jim - the firewall doesn't seem to really deteriorate much in these trucks, w/ the nice mist of oil smoke alla time grin I think you might be better off to use that stuff on the inside of the firewall if what you want is insulation and noise reduction
#118764 12/13/2005 4:57 PM
thanks guys
i have access to a wurth gun and materials. You're correct it is a rubberized type lining, Rhino is harder and would probably not be a good candidate in this case.
Jim & Caroline
#118765 12/14/2005 7:09 PM
A previous owner had coated the firewall of my 1950 3600 with undercoating, presumably to reduce noise and act as an insulator. The problem was that after 20-30 years (I'm guessing) the undercoating had dulled in appearance and looked lighter in color, plus it had accumulated a lot of dirt that was now permanently imbedded in it.
The removal of the stuff was, to say the least, tedious. I found that Easy Off Oven Cleaner (the unfriendly version, not the newer one) worked pretty well at softening it up if allowed to sit for 15-20 minutes after spraying. Then using plastic scrapers I was able to remove most of it. The small bits remaining was sanded off. It took me an entire weekend but it's gone now. The firewall is primered and will be getting a finish coat of black zero rust later.
The insulation/noise reduction material will be going on the interior.
