6 members (Lostbuthaulinass, klhansen, Otto Skorzeny, Charles in CA, Peggy M, Gray_Ghost), 114 guests, and 2 robots.
Topics128,059
Posts1,055,825
V
V Offline
We are building a 1951 1 ton, truck and I wondered if anyon had pictures of a frame or bottom side of a truck that shows how the transmission was held into the truck. The owner delivered the truck in a ton of pieces on a trailer so we aren't certain we have all the parts, and we are not installing the original engine so I have nothing in the front to bolt it to right now either. Thanks in advance for any help.
You can take the girl off the farm, but you can't take the animals out of her truck.
Watch the build of my 1954 Chevy at www.v8tvshow.com
Transmission hangs entirely off the bellhousing. The bellhouing is supported on rubber mounts on the crossmember. The engine also has a front center mount.
1952 Chevrolet 3800 pickup
---All pictures---
V
V Offline
AHHHH This must be why it seems to us we are missing pieces. We don't have the original bellhousing, and We are going to have to use a different bellhousing anyway due to the small block chevy we plan to install so I think this means we are back to the drawing board. Thanks so much for the quick response.
You will have to fabricate motor mounts and a transmission cross member. You will find help with your modifications in the HiPo Forum. Fun project good luck.
Seems you could use a 1954 model transmission crossmember and bell housing from early V8 that fits such crossmember. Then only need to fabricate or modify front engine mount?
---All pictures---
If I remember right---- you can use the 1955, 56, and 57 chevy car, or truck v8 bellhousing, as they have the side mounts, or you will have to build a cross member for the side mounts of the v8 and a crossmember for the tailshaft of the transmission. The 51 transmission will bolt up to the 55 56 57 bellhousing.
