| | | Forums66 Topics128,051 Posts1,055,711 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 56 | We are building a 1951 1 ton, truck and I wondered if anyon had pictures of a frame or bottom side of a truck that shows how the transmission was held into the truck. The owner delivered the truck in a ton of pieces on a trailer so we aren't certain we have all the parts, and we are not installing the original engine so I have nothing in the front to bolt it to right now either. Thanks in advance for any help.
You can take the girl off the farm, but you can't take the animals out of her truck. Watch the build of my 1954 Chevy at www.v8tvshow.com | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Transmission hangs entirely off the bellhousing. The bellhouing is supported on rubber mounts on the crossmember. The engine also has a front center mount. | | | | | Joined: Jan 2008 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 56 | AHHHH This must be why it seems to us we are missing pieces. We don't have the original bellhousing, and We are going to have to use a different bellhousing anyway due to the small block chevy we plan to install so I think this means we are back to the drawing board. Thanks so much for the quick response.
You can take the girl off the farm, but you can't take the animals out of her truck. Watch the build of my 1954 Chevy at www.v8tvshow.com | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | You will have to fabricate motor mounts and a transmission cross member. You will find help with your modifications in the HiPo Forum. Fun project good luck.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Seems you could use a 1954 model transmission crossmember and bell housing from early V8 that fits such crossmember. Then only need to fabricate or modify front engine mount? | | | | | Joined: Aug 2011 Posts: 22 'Bolter | | 'Bolter Joined: Aug 2011 Posts: 22 | If I remember right---- you can use the 1955, 56, and 57 chevy car, or truck v8 bellhousing, as they have the side mounts, or you will have to build a cross member for the side mounts of the v8 and a crossmember for the tailshaft of the transmission. The 51 transmission will bolt up to the 55 56 57 bellhousing. | | |
