5 members (Hotrod Lincoln, Hanks custodian, Gdads51, Gray_Ghost, Maybellene), 80 guests, and 3 robots.
Topics128,066
Posts1,055,871
Members48,428
#118740 12/06/2005 1:28 AM
' Offline
Hey guys, new question for the day, on a '46 GMC 2 1/2 Ton how does the hood fasten at the front. Is there a pin that slides in from the hood into what looks like a crome arch? Any help woold be appreciated. Mine hood fell off!!
Scott
#118741 12/06/2005 7:40 PM
Scott- Each end of the hood hinge should have a "pin" sticking out of it. These pins are part of the hinge and not a seperate piece. The pins fit into a small clip at the back and into a hole on the hood ornament at the front. It's fairly common for one or both of the pins to break off since they are just rolled sheetmetal. You may be able to repair it, or you may be able to find a good hinge and bolt or rivet it back on.
To be long remembered as he's cruising in
The Passing Lane
#118742 12/06/2005 8:21 PM
The other problem you may have is the hood ornament itself - they are cast and the socket that holds the hood hinge rod sometimes breaks away.
1940 Chevy KC 1/2-Ton
#118743 12/07/2005 4:27 AM
'46 GMC hood ornament should be chrome plated and made from stamped steel. Not sure if they were the same in Canada though?
The Passing Lane
