7 members (Hotrod Lincoln, bobfake, GRNHydra, tclederman, Woodcmiami, Otto Skorzeny, 2-Ton),
43
Mod | | | Forums66 Topics128,091 Posts1,056,034 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 51 | Hey guys, new question for the day, on a '46 GMC 2 1/2 Ton how does the hood fasten at the front. Is there a pin that slides in from the hood into what looks like a crome arch? Any help woold be appreciated. Mine hood fell off!!
Scott | | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | Scott- Each end of the hood hinge should have a "pin" sticking out of it. These pins are part of the hinge and not a seperate piece. The pins fit into a small clip at the back and into a hole on the hood ornament at the front. It's fairly common for one or both of the pins to break off since they are just rolled sheetmetal. You may be able to repair it, or you may be able to find a good hinge and bolt or rivet it back on. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | The other problem you may have is the hood ornament itself - they are cast and the socket that holds the hood hinge rod sometimes breaks away. | | | | | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | '46 GMC hood ornament should be chrome plated and made from stamped steel. Not sure if they were the same in Canada though? | | |
