7 members (Tinker5, chevy51truck, Gdads51, Hotrod Lincoln, Woodcmiami, 3800GUY, Bill Hanlon), 148 guests, and 2 robots.
Topics128,036
Posts1,055,458
Members48,422
#118712 12/03/2005 6:49 PM
My 36 low cab is being painted..finally! three coats color and three coats clear..I have read for a deap gloss, to handrub between the first and second clearcoats..any comments...we are using PPG on body/bed and Dupont's best Black on fenders.
bruce duykers
#118713 12/03/2005 8:10 PM
Junior Member
Junior Member
The best proceedure is to shoot the clearcoat, let it sit about two weeks, and then wet sand and buff. Start sanding with 1000 grit wet/dry paper to remove the orange peel, then use 1500 grit wet/dry to remove the scratches from the 1000 grit. With the 1500 grit, I sand in an orbital style by hand. Then start your buffing with a wool pad and a heavy cut compound. After that, use a foam pad with a finishing compound. The PPG clear dries VERY hard, and can be difficult to buff, but the final finish is worth the effort. Don't even think about trying to hand rub out the clear.
