4 members (WICruiser, Bill Hanlon, Hanks custodian, 66flea), 235 guests, and 3 robots.
Topics128,078
Posts1,056,049
Members48,433
#1185537 10/05/2016 1:51 AM
Had this rebuilt 3 months ago as I was having same problem. Worked fine until a couple weeks ago. I do get gas up to carb, just not into it. I pour a little gas in and it starts up but dies when that fuel runs out. This is a Rochester 1 barrel on a 235. My truck is a 1951 GMC 3/4 ton. Also, for a couple of starts a while back, I had gas leaking out of the carb. But it stopped and didn't have that happen anymore. I've changed the fuel filter multiple times and fuel looks clean. What should I check on the carb? Plan to pull it here soon.
Problem with float adjustment or stuck closed.
Your float may be bent to the side and is contacting the side of the bowl, preventing the needle from opening.
Pulled carburetor and float seemed fine. Removed float and needle valve was stuck with sediment. Flushed out with carb cleaner and changed fuel filter which had sediment also. Started up fine. But in attaching choke cable, I couldn't figure out how to put it back to close smoothly. After several attempts, I broke off the cube with the screw. Is there a way to replace this? Looks like it swivels and attached like a rivet. Don't know what that part is called. Doesn't look like the linkage can be removed either. Appreciate any help.
Send a PM to carbking.
Maybe someone that knows your carb well can answer you.
Jeffrey
Not sure what a PM is or how to send one.
PM is a Private Message. Click on the users name such as Rudedog53 and a window opens showing their profile. In the profile is a block saying send Private Message. Click on that box and type your message. It will only go to the person you select. Hope this helps.
Thank you!
Carbking isn't accepting PM's. But at least I learned about PM's!
Check thecarburatorshop.com it is Carbking's website. There is a contact us link listed.
