0 members (), 134 guests, and 4 robots.
Topics128,149
Posts1,056,818
Members48,456
I did not pull the engine so I do not know what type of bolts, washers, nuts, length and diameter were used on the front motor mount. Except that the bolts are carriage head.
When I got the 1954 235 it was already separate from the rolling chassis.
Back story:
I am trying to get a front motor mount and the correct bolts. I have two of the four pieces that make up the front mount. A new rubber and the bottom plate. I am missing the two metal plates that sandwich the rubber piece.
My son's 1946 truck is going into the shop to have the 1954 235 rebuilt engine put back in.
I will be bringing the original 1946 engine back home, putting back together and mount the old engine on a 1945 1/2 ton rolling chassis. Going to use the chassis as an engine stand.
I don't know if I will ever do anything with that chassis but the plan is to keep the engine until the day my son decides to sell the truck. This way the new owner gets the original engine.
Thanks for reading all of this. Jeffrey
Jeffrey,
This may help:
http://www.stovebolt.com/techtips/engines/motor_mount_front/index.html
I was never able to source the original fine thread carriage bolts that mount to the engine. Locally sourced grade 5 coarse thread bolts can be found (but even those will take some searching...I found some marketed by Hillman). I believe the bolts are 7/16 diameter, but would have to double check to be certain.
Paul
Lots more pictures
Yes I already saw that tech tip. Thanks though because I'm sure someone has never seen that article before has learnt about it on my thread. Just the way I learnt about it reading someone else's thread. Stovebolter's Are Great.
Jim Carter sells the rubber and the metal plate that sits on top of the frame. I already have those two pieces and the two rear mounts.
I need the two metal pieces that sandwich the rubber.
JC lists the complete front mount assembly but it is on back order and they do not know when they will be available.
If you saw my garage you would know why I need to mount the 46 engine on the 45 rolling frame. There is no more open floor space. I'm "this" close to having to walk on things instead of walking around them. And I will have to bring the engine home by Friday. Jeffrey
' Offline
Jeff, Photo of front motor mount assembly.
@photobucket
http://i669.photobucket.com/albums/.../mount%20parts%202%20aaa_zpshmhl8bep.jpg
What parts do you need ?
I can probably find them for you GM NOS
Engine - Front Motor Mount Kit GM # 2224010
Kit contains:
1.) Plate - GM # 3657522
2.) Retainer - GM # 368449
3.) Shield - GM # 3656502
4.) Bolts ( 2 ) - GM # 3701135
5.) Washers ( 2 ) - GM # 352282
6.) ( 4 ) - Nuts
@photobucket
http://i669.photobucket.com/albums/...%20Swap%20Meet%20%202011_zpsoqy4jz08.jpg
I know where you can get this front engine mount kit GM NOS
Chevy Parts Manual showing contents of GM Kit 2224010
http://i669.photobucket.com/albums/vv57/glp0329/Motor%20Mount%20Parts/GM_2224010__zps0gt16egm.jpg
Washer & Bolt from GM Motor Mount Kit # 2224010
http://i669.photobucket.com/albums/...OS_/new-1b_zpssunzurts_b_zpshkjze9mv.jpg
GM # 3657522 - Motor Mount Plate
http://i669.photobucket.com/albums/...ts_GM_NOS_/3657522_plate_zpsgjfxfoif.jpg
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
@photobucket
Kit contains:
6.) ( 4 ) - Nuts
@photobucket
George
'54 3600
George, thanks for the help.
I have a repo - Shield - GM # 3656502
and - repo rubber.
I need the 3657522 and the 368449.
Though I would like to get the original 3656502 as well.
I also will need 4 bolts, washers and nuts.
So if you can find those parts please let me know. Thanks a lot. Jeffrey
' Offline
PM sent
George
'54
3600
1954 3600
Now cruising in
The Passing Lane
Jeffrey -
I posted details about installing motor mounts in my '54 3104 a few years ago. The post included part numbers and sources. I also posted corrections to some info that was incorrect. PhotoBucket photos load a little slow
Scroll up and down in the threads to see all comments.
Maybe this will help ...
> Recap of motor mount installation '54 3104
> Correction about carriage bolts
> Most of the same info, corrected info about location of "thick washers"
> The correct way to install the "thick washers"
- Lonnie
- Lonnie
My '54 3104
This part has often been portrayed on this forum incorrectly. The special thick washers are supposed to be mounted under the front cross member, at least if one chooses to follow the shop manual. Read the assembly order in last sentence of the engine mounting section.
[img]http://www.surfacezero.com/g503/data/3285/medium/IMG_21144.JPG[/img]
http://chevy.oldcarmanualproject.com/military/1942/42cm4x2t0622.htm
Lots more pictures
The 1954 Shop Manual description of the front engine mount (6-13, 6-14) differs from the 1942 Manual. The washer is not mentioned in the 1954 manual.
The diagram of the front engine mount in my Reproduction 1947-1947 Truck FAM lost detail (Sec 6-Sheet 12.00). However, the arrow and tail for "365685 SP WASHER" indicates that the washer sits on top of the cross member and under the retainer.
FAM Sect 6 - Sheet 12.00
- Lonnie
- Lonnie
My '54 3104
Hi Lonnie,
If you enlarge the 1954 diagram posted, the thick washer is located under the crossmember in the same assembly order as verbally described in the referenced 1942 manual. Note that part of the washer circumference in the diagram is occluded indicating it is below the crossmember.
Lots more pictures
