9 members (klhansen, Southerntruck, Barry Martak, TexasJim50, Gdads51, J Lucas, Stovebolt48, Hotrod Lincoln, tclederman), 120 guests, and 2 robots.
Topics128,089
Posts1,056,422
Members48,443
Working on getting the hood to properly fit on a 41.
Is there a gasket that goes between the hood side panel and the front upper fender bracket?
See pictures:
Closed
http://i1296.photobucket.com/albums/ag13/catfish_fry/20161009_155456_zpswy2qmkym.jpg
Open (see shaded area)
http://i1296.photobucket.com/albums/ag13/catfish_fry/20161009_155503-Txt_zpsayxd4pdh.jpg
Thank You,
V
VEW Offline
V Offline
Yes there is. I took one off during disassembly and I think I got one with a gasket kit.
I'll check now.
~ Victor
1957 3100 - moved on
V
VEW Offline
V Offline
I think it's the same material that goes on the cowl; between cowl and hood.
~ Victor
V
VEW Offline
V Offline
Here's a pic of what I got years ago:
41 hood lace
I just now opened the package. Has product code of FP115, but don't know what vendor I got it from. Package had 4 strips: one for each side of the hood to cowl, and one for each side of the area you are asking about.
~ Victor
Thank you for the information.
I purchased the rubber version, part number FP116 from Jim carter. It came with 2 pieces that are long enough for that location. I am wondering how to mount them and they also seem to be too thick to fit there.
I may just go with something thinner and use contact cement???
Thoughts?
We ended up finding a rubber grommet much like what is used for the hood to upper grill but larger around and more flat. This should work just great. No pic yet to post.
