0 members (), 129 guests, and 1 robot.
Topics128,115
Posts1,056,292
Members48,439
I replaced the brass bushings on the clutch pedal mount in the frame, cleaned up the lower clutch pedal arm, lubed and reinserted, but it seems to stick/have resistance rather than turning freely, so much so that the spring does not return the pedal correctly.
Has anyone had a similar issue - any suggestions?
gobolt
Riding in the Passing Lane
You need to hone the bushings out a little. If the clutch pressure returns the pedal but the return spring does not return it rest of the way, I would drive it awhile that way & it will wear in. Pull it up with your foot after you go through the gears.
1972 Chevy c10 Cheyenne Super
Bushings honed and it returns smoothly - thx!
gobolt
