| | | Forums66 Topics128,076 Posts1,055,924 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 22 'Bolter | | 'Bolter Joined: Apr 2011 Posts: 22 | I replaced my 50 door glass today both sides. I ordered the setting tape. It had green thin plastic on one side. I didn't know it was suppose to be removed. I took a paint brush and oiled one side of the tape. Do I need to do this again and remove the plastic. I messed up and ordered two rolls of tape.
When setting goals in life. Always aim low to avoid disappointment
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | It's probably to keep the rolled up tape from sticking to itself. You do not want the plastic to be left on there.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2011 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 27 | Depending on what type of tape you, I used lacquer thinner on the tape to make it slide on the channel, once it dried it really becomes sticky. I have never seen any with a green side on them, from my glass shop days in the 80's | | |
