0 members (), 133 guests, and 2 robots.
Topics128,157
Posts1,056,876
Members48,458
Has any one attempted to put 37 front sheet metal on a 39 cab. is this possible ? And what problems did you have ?
back yard wrench turner
Good question!
Answers might be found here: body dimentions
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
I want to put a 37 or 38 front fenders grill and hood on my 39. Just wondering if anyone has done this before. I'm pretty sure it's not going to bolt right on but also it's probably not impossible to make it work. I think the hood will be the biggest challenge and the area where the running boards bolt to the front fenders.
Might try posting this in the Paint and Body Forum for more expert answers.
No. Cab is different, two piece windshield, different doors, slight difference in shape, fender shape is different, fenders will not mount to running boards.
Now, depending on how much work you are willing to do, you could probably make it fit. It might fit the frame since the same frame was used up through 54. Bolting it to the frame might be similar, but just to set on a 37 frame with a cab and front end and hope to bolt it up totally and to the cab too - no.
