7 members (TUTS 59, Bill Hanlon, Otto Skorzeny, 50Chevy3100, cmayna, UnclePaddy, 1 invisible),
129
Mod | | | Forums66 Topics128,042 Posts1,055,509 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 2,306 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,306 | Anyone know what type of glue to use on a steering wheel to fix the cracks .I was thinking of using a epoxy glue ,chevy of the 40,s sells a glue for the wheel but I would think it is a common glue that can be purchased at a hardware store. | | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | I have repaired several steering wheels, I used JBStik epoxy putty, and it worked well. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I used 3M 2 part panel glue for mine. It set up at nearly identical density as the origin material. Way easier to form and finish than JB or other epoxies like it.
| | | | | Joined: Nov 2012 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2012 Posts: 39 | I just finished repairing a bunch of really bad cracks on the steering wheel for my '58. I used PC-7 epoxy. It is available at Ace Hardware. It is the same thing that comes in a lot of the kits available for steering wheel repair.
Chad | | | | | Joined: Sep 2010 Posts: 2,306 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,306 | Thanks for the suggestions . I have a spare wheel and I will be trying these to repair .thanks again | | |
