7 members (wilbur53, Rusty Rod, D B Cooper, RaNfLaS, Gdads51, KEVINSKI, 1 invisible),
114
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,060 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 2 Moderated | | Moderated Joined: Oct 2016 Posts: 2 | I just bought a 1963 C30 (numbers matching straight 6 and 4 on the floor). I was looking for advice on how to make it a better DD. I want to keep it as original as possible but I'm not against modernizing the engine, I just don't know how...
So here's what I'm looking for: - engine reliability - tires/wheels (I've got split rims up front that I'm not to fond of working on) - transmission - gearing
1963 C30 Flatbed 1984 CUCV
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Your questions are a little to vague to answer. But, like buying any used truck, you need to take a close look at everything to make sure everything is working as it should. I don't believe there is anything on the truck that cain't be repaired or replaced to keep it in service. I would change all fluids, lube all the grease points. Get it up on a lift and check all wear points like ball joints. Replace worn parts. Run a compression check and monitor oil usage on engine. Keeping it orginial as possible will make it easier to sell when the time comes. Questions on the different sections of the truck can be addressed in the shop section of this forum. The guys here have "been there, done that" and will be glad to help. Welcome and good luck with your truck.
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Welcome to the site. Motor of that age can meet the dd reliability metric. Won't get great mpg, but with right periodic maint it will be fine. Compression check and oil checks as suggested. My 66 w/250 considered. Many others can 2nd. Wheels tires and brakes are needed. Look for Grigg to suggest wheel compatibility. Check into the drive line forum for rear differential and or axle recommendations. There are others in the ga area with 60-66 know-how. Hambone | | | | | Joined: Jun 2005 Posts: 45 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 45 | I had a 66 C30 250 4spd 5.13 rear. It was slow and a workout. At times I hated driving it, but I would have no issue driving it daily if in good condition stock. To improve mine I purchased a complete 83 dually to swap everything into the 66. disc brake front end sway bars 454 etc.
The 6cyl is reliable and can take a lot of abuse. I ran mine 80mph up the interstate a few times only letting off when the valves started floating and it took it no problem. If you want power a v8 swap or even a LS swap would be my choice.
The trans is a SM420 and bullet proof but for higher speed I would swap to a NV4500 5 speed, or a 4L80 automatic.
The rear is also bullet proof but harder to find parts.I would leave it alone, swap to 4.10's ,or a later rear. Single wheel or cab and chassis would be the correct width.
For wheels, any newer chevy 8 lug wheel should work . Up to 1995 possibly newer wheels also? I used 19.5 wheels off of a P30 stepvan.
80's C30's can be found cheap buying one and swapping everything over would be the quickest way to a cheap fun daily driver and stay looking stock somewhat.
Richard 42 Chevy pickup 65 Chevy C10 Panel | | | | | Joined: Oct 2016 Posts: 2 Moderated | | Moderated Joined: Oct 2016 Posts: 2 | Thanks for the suggestions. I'll keep y'all up to date on the progress.
| | | | | Joined: Nov 2007 Posts: 131 Certified Bolt Nut | | Certified Bolt Nut Joined: Nov 2007 Posts: 131 | Keep in mind that these trucks were daily drivers when they were built. The roads have gotten better, but highway speeds have gotten faster and it's unrealistic to think that a bare stock 1960's truck will be equal to a modern vehicle. Only you know what your "daily driving" is like and if the level of "comfort" will be enough to be considered something you would want to do daily. If you are asking if the truck can be made reliable enough to be a reasonable daily driver? I would say yes, but not without the typical wrenching that you would have had to do in the 1960's. Modern vehicles have spoiled us as far as drive and forget (other than oil changes, brakes and batteries) | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | welcome back sixtyfive c-10. sort of a long nap you had hope all is well Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2010 Posts: 9 New Guy | | New Guy Joined: Feb 2010 Posts: 9 | i took a 1995 dodge 12v cummins 5 speed. and removed the body. installed a 65 c10 on it. had to due custom work on the fire wall for the clutch. it has disk vacum brakes. lowered it 4 inches. have done no body work, still run c-10 gauges, it turns alot of heads, | | |
