| | | Forums66 Topics128,176 Posts1,057,058 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | I would appreciate it if someone could provide me with pictures of the correct way to connect the positive and negative battery cables, what they connect to, and how long they are. Also would like the same thing for the grounding strap(s). I have two braided straps, one with a battery terminal connection, that were removed from my 1958 235 Apache 3100 quite a few years ago, and I want to know what goes where.
Thanks guys. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | factory cables run down behind the battery, + goes to the main starter post, braided ground goes to a boss on the firewall behind the battery ... the other braided ground goes from a starter mount bolt to the lower firewall as seen here - all just long enough to reach Bill | | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | Unless you're building a 100% original show truck, do yourself a favor and use a ground cable long enough to reach a bellhousing attaching bolt near the starter, then use smaller gauge ground wires or braided ground straps from the engine to the frame and/or the body and bed. The starter pulls the most current of any of the electrical items, and it needs a very low resistance ground circuit- - - -#0 cable or larger with a minimum of connections to negotiate. Jerry
| | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | Bill,
This is very helpful.
Thank you,
John | | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | Thanks Jerry. Going with a 100% restoration or as close as I can get.
John | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | OK, buddy just dropped off his 56 for the winter, got the thousand words for ya - batt ground, not a braided strap in this case, but connected where the factory put it for 55.2-59, about 10-12" long .... engine starter ground is as in the pic I posted above, measure from that boss on the firewall to a starter mount bolt, and for the battery measure from the batt to the starter Bill | | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | | | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | Thanks Jerry. Going with a 100% restoration or as close as I can get.
John My kids were thankful for guys like you- - - -they ate a lot of good meals from the money I made fixing hard start/no start problems because of dirty grounds. Check and clean all the connections about every six months. Jerry
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | raleigh58, If you are interested in authenticity, do you have a 55-59 Factory Assembly Manual? If it is like the earlier manual, it will show battery cable locations. Most likely the battery cables were 4 gauge (2 gauge to 4 gauge should work fine). As posted above, be sure all battery cables/leads connectors are clean/shiny and use anti-oxidant conductive grease on the connection surfaces (available in small tubes at most auto parts stores). | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | If you don't have the manual, there is one for sale in the swap meet Stovebolt Miscellaneous forum.
1959 3100 Apache Fleetside
| | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | Thanks to all respondents for the good information and tips. Yes, I do have the manual Cablesmill referred to and will check it once more. | | |
