5 members (Donf, rfs56trk, DoubleB, BillCollins, Wally / Montana), 58 guests, and 3 robots.
Topics128,090
Posts1,056,022
Members48,430
#1185401 10/04/2016 1:27 AM
In anticipation of winter, I have been working on my 58's deluxe heater. I think I've got most of it done, but am having trouble with the fan. It turns when I turn the key (235 with a pedal to start) and the lever doesn't change the speed.
Did I wire it backwards or is the switch failing somehow? Any help will be greatly appreciated--even more so in a couple of months...
'58 Task Force
'59 MGA
'97 F150
'06 9-2x
Kwangtzu #1185412 10/04/2016 1:54 AM
Can you take pictures of how you did wire it, and or make a diagram?
If on all the time with ignition on and fan switch does nothing then yes it is wired wrong. Without seeing I'm not sure exactly what to suggest beyond look at and rethink how it should be wired, test switch functions with meter to show you how it should work.
1952 Chevrolet 3800 pickup
---All pictures---
Kwangtzu #1185482 10/04/2016 5:00 PM
F Online: Content
Ed
Kwangtzu #1185530 10/05/2016 1:08 AM
Thanks Ed and Grig.
I used the accessories manual from 1955. Attatched the brown wire to the passenger side terminal and ran power from the accessory terminal on the ignition switch to a junction box then to the driver side terminal.
I took a picture as you suggested, and see that the cardboard sheathed wire coils came disconnected during installation and seem to be shorting across the two terminals. That's probably my problem, no?
Haven't figured out how to attacha picture. I'll do that in a bit, I imagine.
'58 Task Force
'59 MGA
'97 F150
'06 9-2x
Kwangtzu #1185531 10/05/2016 1:11 AM
[image]https://drive.google.com/file/d/0B_4kZkWEpG3wXzZ5ZHhyWGs3VlpzRzRBVVE0Zi0xUElsdVJR/view?usp=sharing[/image]
Is this something I can repair? (I have a soldering iron and multimeter) I'll look to see if I can buy one. Is there an alternate?
'58 Task Force
'59 MGA
'97 F150
'06 9-2x
Kwangtzu #1185557 10/05/2016 4:25 AM
I'm not familiar with that switch or model truck but looks to be a resistor for lower speed and it looks kaput.
At a minimum you could remove it and probably have high speed only. Later replace the broken parts.
---All pictures---
Kwangtzu #1185564 10/05/2016 5:36 AM
that looks pretty much how it should be, as seen here in the repro switch available from the vendors [see EL74 here ] .... and here's the install guide from '57, which should allow you to sort out the wiring
Kwangtzu #1185586 10/05/2016 12:29 PM
I thought looked like the resistor was riveted to the back of the switch and now half torn off, thus kaput?
---All pictures---
Kwangtzu #1185615 10/05/2016 6:31 PM
Thanks for the good pictures and a source, Bill. I found the entire unit on LMC, but it was around $240...
I think you're right, Grigg. As it was, it was jumped past the resistor ( I didn't know that's what it was), so highspeed only, as you said. This is a driver, I don't suppose a modern resistor is a viable option here?
I'll pull it out again and see if it's re-attachable, but it looks pretty rusted. If not, it's not too cold in Indiana yet, so I can wait for a part I guess.
'58 Task Force
'59 MGA
'97 F150
'06 9-2x
Kwangtzu #1185674 10/06/2016 2:51 AM
A later-type speed control resistor could be adapted, one that sits in the airflow from the fan to keep the connectors from melting. It would require some creative wiring and possibly the addition of a high/low speed toggle switch hidden somewhere under the dash. That would involve cutting a small rectangular hole in the blower duct work to mount the resistor.
Kwangtzu #1185684 10/06/2016 3:24 AM
Sounds like more work than it's worth. I'll just order the replacement. Thanks for the help!
'58 Task Force
'59 MGA
'97 F150
'06 9-2x
Kwangtzu #1185685 10/06/2016 3:35 AM
Your choice- - - -the resistors I'm talking about are on Ebay for about 10 bucks, brand new.
Kwangtzu #1185692 10/06/2016 4:49 AM
Or just use the fan on high or off.
---All pictures---
Kwangtzu #1185742 10/06/2016 8:37 PM
As far as wire lugs or connectors go, they make a hi-temp nickel connector. Available at an appliance repair store.
