5 members (Wayne67vert, Gray_Ghost, tclederman, Ridgeback, 1 invisible), 56 guests, and 5 robots.
Topics128,021
Posts1,055,372
Members48,420
#118539 11/23/2005 12:11 AM
Can you paint the headers? Would you use that 'engine enamel' stuff?
GO RANGERS grin
Photos Updated so check them out!
#118540 11/23/2005 2:25 AM
You can get high temp spray paint at a car parts store. You need to use the kind that is rated at 1500 degrees. I used it on my exhaust pipes and so far it has held up well. If you dont mind paying a little more, ceramic coating works good, it holds up on headers better than about anything I've seen so far.
#118541 11/23/2005 2:29 AM
thanks hsh
GO RANGERS grin
#118542 11/23/2005 5:29 AM
one thing that helps keep them from discoloring is to have the headers warm, but not too hot, when putting the paint on
