0 members (),
297
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2016 Posts: 107 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 107 | Hey, Guys I am learning aboout my dads old truckit is ecerything of a 1951 gmc pickup but the motor is a 248 with a A in front of the motor number which the motor number is (A 248 I 45293) I think after alll i have read is this motor had been replaced by gmc according to my mother the first motor went bad before warrenty went out and they as gmc put a 248 motor in the truck instead of a 235. this truckhas 8 leaf springs on each wheel. I need somebody to help me with this, i am getting ready to sand blast and prime this comming saturday.so if anybody can help me i would really appricate it. If it would help my e-mail address is ( [email protected]) Thank you'll, Moonshine Mike
| | | | | Joined: May 2014 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: May 2014 Posts: 27 | A is a notation of bearing set dimensions, there are a few different sizes A B C etc.
the 51 GMC, in fact any GMC, did not come with a 235, the GMC got a special line of high pressure oiling engines. you cant install a 235 where there was a 228/248/270 and vice versa, the GMC engines are about 5 inches longer which is why the radiator is tucked inside the core support.
the 248 is correct for 1951 GMC. if you have a 248 and 8 leaf springs, I would bet it is a 150 which is a 3/4 ton. | | | | | Joined: Aug 2016 Posts: 107 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 107 | Is there any other way to tell if it is a 3/4 ton or a reg. p/u | | | | | Joined: Aug 2016 Posts: 107 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 107 | can anybody tell me if the truck i have that has 8 leaf springs is a reg. p/u or a 3/4 ton . | | | | | Joined: May 2014 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: May 2014 Posts: 27 | whats the VIN number on the drivers door jamb plate?
also, the hood should say 100/150/200
A 3/4 ton will have 8 lug axles and single rear wheel, with an 8 ft long bed. the shifter will be on the floor and it will be a 4 spd. you can get a one ton single rear wheel, but I think a one ton will have more than 8 leafs. | | | | | Joined: Aug 2016 Posts: 107 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 107 | the vin. # had been gone off the door, and all it had on the hood was a gmc emblem no numbersw of such , so i am trying to figure this one ot it has a short bed with 2 stakes on each side. Just trying to figure this one out. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | ... the GMC engines are about 5 inches longer which is why the radiator is tucked inside the core support.
...the 248 is correct for 1951 GMC. The GMC engines were about 2" longer than the Chevrolet engines. The truck would have come with a 228 originally. 248s came in 2 ton and larger trucks. Dealer replacement with a 248 under warranty is very possible. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If you have a 1951 short bed GMC frame, it would be a 1/2 ton model. A is a notation of bearing set dimensions, there are a few different sizes A B C etc. . . . The "letter" preface in the Engine Serial Number was used to indicate a variety of possible combinations of "non-conformities" to "standard" engine specifications for cylinder bore and crankshaft journal/bearings specs: "A" preface specified: + 0.005" cylinder diameter bore - 0.010 main bearing journal diameter - 0.010 rod bearing journal diameter | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | can anybody tell me if the truck i have that has 8 leaf springs is a reg. p/u or a 3/4 ton . . . . A 3/4 ton will have 8 lug axles and single rear wheel, with an 8 ft long bed. the shifter will be on the floor and it will be a 4 spd. you can get a one ton single rear wheel, but I think a one ton will have more than 8 leafs. 1951 GMC light truck standard spring-set leaves: front springs: 8 on 1/2 & 3/4 ton, 7 on 1 ton rear springs: 8 on 1/2 ton, 7 on 3/4 ton, 8 on 1 ton | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | 1 ton, a GMC model 250, will have 137" wheelbase and if a pickup truck it has a 9' bed (4 stake pockets per side). The frame rails behind the cab are also flat on top. A 3/4 ton has shorter bed and often slight hump in frame over rear axle. Both have 8 lug wheels, and springs may have been changed or perhaps special ordered differently than expected. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | 1951 GMC Specifications , compliment of Rob English. | | |
