Hi, just got my 3100 on the road today.Really enjoying it,but a couple of things need sorting,firstly it jumps out of top gear if you come off the throttle too quickly. It feels like an adjustment issue as it doesn't really feel like it goes all the way in like the other gears.(Its a 3spd column shift.)
Also the overall gearing needs raising,the 261 motor feels like its straining over 45mph. I've read that all it needs is different diff ratio's. Any help with a good source bearing in mind I'm in the UK,would be greatly appreciated.
