SWEET, I think I'm in the right forum, but please move it accordingly.
I'm working to get my 41 back on the road. The truck already had some mods made by PO when I got it 20+ yrs. ago. SBC installed, brakes were changed to Bendix type (I think) and it had the MC mounted on the firewall (although not the proper one).
So, after I mistakenly let the truck sit for umpteen years, I'm working on it. Installed a good 350 with 700r4. I'm ready to start the engine, but figured I should get some braking power first.
I've searched the site and read many threads, but I think I now have a brain f*art and need some help from all you knowledgeable Bolters.
I thought I knew what I was working with, but need confirmation. These are a Bendix brake system, right?
41 LF 41 LR Are these from TF?
I thought I had 14" brakes, but they are 11", right?
11 brakes? How can I identify what type of rear differential I have? As you can see, I need to replace the rear seals.
Finally, I need to get the proper MC for the drum/drum system. I spoke to several vendors and only disc/drum is available. I understand I will need a 10 psi residual valve on the disc side. They offer a MC with 1.25" bore, so that should work, right?
I noticed a MC and brake pedal system is offered (which is what I will need). Anybody had any experience with that system and is it working well for you?
As always, thanks for your advise, suggestions, recommendations, etc.
Much appreciated.
