| | | Forums66 Topics128,203 Posts1,057,412 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2016 Posts: 12 New Guy | | New Guy Joined: Sep 2016 Posts: 12 | I'm looking at a 1950 project truck its torn down to the frame, motor and tranny are gone. The owner says he does not have the VIN or Registration. Are there any places on the body or frame that I should be looking for some sort of ID numbers? I don't want to get stuck with a stolen vehicle.
Main reason I'm interested is that the frame is done with 4 link rear and has a front Camaro clip on it... I can't buy the parts for what he is asking.
| | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | Some of the GMC's had the number stamped on the right front frame outside. | | | | | Joined: Sep 2016 Posts: 12 New Guy | | New Guy Joined: Sep 2016 Posts: 12 | Some of the GMC's had the number stamped on the right front frame outside. Thx! | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I never buy a vehicle without Title. If the GMC does NOT have a frame number, you can use it's chassis with a body that has a Legit VIN and title. It would be like buying a FatMan chassis for a truck I think. You can not, however, grind off or fill in the frame stamp on that 4 link/Camaro chassis if it has one. You will have to see what the Gendarmes say. The question, Where did he get it? Does he have Bill of Sale? Can you contact the previous owner? Why no title? The price should be very very cheap...1. No title, 2. Not many buyers interested in those mods, 3. Mods may be done shoddy. 4. Risk re: untested components (can't drive) 5. Torn apart may be missing parts. Look on both sides of frame. Cletis (moderator) knows if and where it is. In Arizona, they don't look at the vehicle, just transfer the title.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | This gets discussed a lot. Most states used the engine number on the title as the VIN through '55. Every state has a process through which to obtain a title when a vehicle has none. You should contact your state licensing authority to find out what that process is in your state. Having said that I now see you're in Canada. The answer is the same. You'll need to contact the authorities in your province. Good luck with it.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The stamped numbers on GMC frames ended in the late '40s. The '50 won't have one. Plus this info applies to US built trucks. I don't know if Canadian production ever had frames stamped. | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | My 1949 Check 1/2t has an ID plate attached to the drivers side door casing between the hinges on the body.
Ed
| | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | If that Camaro front clip has a VIN number anywhere on it, I can see the possibility of a whole load of legal problems if you can't prove where it came from. I'd run fast and far from that deal unless the seller comes up with some paperwork. When you start factoring ambulance chasers' fees into the cost, that bargain might turn into a nightmare! Jerry
| | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | I never buy a vehicle without Title. If the GMC does NOT have a frame number, you can use it's chassis with a body that has a Legit VIN and title. It would be like buying a FatMan chassis for a truck I think. You can not, however, grind off or fill in the frame stamp on that 4 link/Camaro chassis if it has one. You will have to see what the Gendarmes say. The question, Where did he get it? Does he have Bill of Sale? Can you contact the previous owner? Why no title? The price should be very very cheap...1. No title, 2. Not many buyers interested in those mods, 3. Mods may be done shoddy. 4. Risk re: untested components (can't drive) 5. Torn apart may be missing parts. Look on both sides of frame. Cletis (moderator) knows if and where it is. In Arizona, they don't look at the vehicle, just transfer the title. Oh Arizona looks. You got lucky. Had cops in the garage and haul it to the DMV FOR A LEVEL II inspection. I'm legal. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I got lucky 30 times in a row. You had a non typical situation you don't mention. If you are talking AZ. I'm legal. I take the signed title to DMV and get it transferred into my name. If they ever ask to see the vehicle, I will show them.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | Guess I was unlucky. All good now. | | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | One of my racing buddies narrowly avoided going to jail over a junker Monte Carlo he was building into a round track car. Nashville's finest looked like the Keystone Kops crawling all over the car looking for a VIN number after somebody accused him of stealing a gutted-out body and frame! Jerry
