1 members (delky), 74 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,422
#118435 11/12/2005 2:25 AM
I have a 52 1/2 ton Chev. Five window deluxe.I'm finishing the frame off on. I'm just about done,(well your never really done). First question is how in the ---- do you get the locking strips in the rear windows weather seals? Second , any tricks to get the rear window in? I've got all the other windows in, but that rear one beats me.
Glenn,
Scootin thru with a 52,
Good, Economic and Classic
1952 Chevy 1/2-Ton
#118436 11/12/2005 7:13 AM
There is a special zipper tool that you use to insert the locking strip. The rear window should actually be the easy one, although you could have glass that is slightly oversize or the rubber you have is too stiff. A lot of times the glass is too big, so it may need to be belt sanded or cut the right size to fit.
Paint & Body Shop moderator
#118437 11/13/2005 4:36 AM
Do your self a favor and get the tool, I didn't and put a few scratches into my new paint job. I think you can get it at Napa or other parts stores as some modern vehicles still use that same kind of seal. Good luck.
#118438 11/16/2005 6:49 PM
I've got the tool. I know it should be self explainatory, but how do you use it? There is no way I could pull or push that thing through.
Glenn,
1952 Chevy 1/2-Ton
#118439 11/16/2005 7:53 PM
[img]http://www.americanclassic.com/images/rgtool.gif[/img]
Stick the lock strip through the hole in the tool, starting at one end, and use the tool to poke it into the channel and work your way around the glass.
#118440 11/17/2005 4:48 AM
Don't forget to lube it up with some soapy water.
