6 members (Gray_Ghost, IHPWR, TexasA&M48Truck, KCMongo, TUTS 59, 1 invisible), 107 guests, and 2 robots.
Topics128,034
Posts1,055,540
Members48,425
#1184302 09/26/2016 4:49 PM
running real rich at idle and rpms. vales adjusted and timing is right carb rebuilt last year running aldor plugs cap points and rotor good. any ideas on how to lean out. i read carb jets are not adjustable in rochester b carb
1955 First series 3600 3/4-ton
"A Great Starting Point"
Follow the story and pix in the DITY Gallery
Year of truck and motor size please.
sorry 55.1 chevy 3600 with 235
Has it always run rich?
Check adjustment of float level.
I just got home from a ten mile drive. the engine sounds great and it was running the best it has ever run, but there was one back fire (early in the beginning about 100 yards down the road)and it seams to have more power. its dark now but i'm going to pull a spark plug tomorrow morning to see if is charred. the exhaust does smell gassy. I printed a float adjustment from the manual and will read up on it. thanks
An incorrect base gasket will block the power valve vacuum port causing a very rich mixture.
My Blog
If you have the wrong main jet in the Rochester, it will do that. I had a Rochester for my 216 and it had a main jet stamped 58. That caused it to run rich. The one I have in there now says 51 on it.
1951 1 Ton Completed
66flea #1184501 09/27/2016 11:30 PM
216's run 51's or close to that, and 235's run around 58's. Venturi size is also different from 216's and 235's
My Blog
