7 members (Gdads51, UtahYork, Charles in CA, Joe Franken, Perro, TUTS 59, Shade Baby), 81 guests, and 2 robots.
Topics128,179
Posts1,057,134
Members48,463
Was looking on the shelf at Menards the other day and
noticed that the bargain Flap Disc that they stocked
looked a bit more stout than the ones that I had bought
a week before at Harbor Freight.
http://www.pbase.com/dennygraham/image/164054951
http://www.pbase.com/dennygraham/image/164054952
When you figure you can't use up the last bit on the
thin HF disc you're really only getting a small portion
of what you get by buying a good one for a couple of
bucks more.
Same thing on their PSA 9" discs I bought for my belt/disc
sander. 80 grit from Menards has a thick backing, lots of
grit, lasted for weeks and the peel paper was wax that
came off easy.
The ones from HF are paper thin, the grit only lasts a few
minuets you can't remove the peel paper, that is, if there
is any, so you have to spray them with 3m adhesive to use
them. I don't think the Chinese know what "PSA" is supposed
to mean.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I don't spin anything 10,000-12,000 RPM that says "Made in China".
Lots more pictures
Ex Hall Monitor
Ex Hall Monitor
I don't buy anything that my life or livelihood depend on that say Made In China.
I bought a pair of HF welding gloves - figured what the heck for $6. First time I used them, I noticed a hole in the right index finger. Wasn't too big, so being the cheapskate I am, I sewed it up. Used them again today and there's another finger with a hole in it. Went and bought a decent pair from the local hardware. Maybe I'll use the HF ones for kneeling pads - or maybe I'll toss them.
If you're still working and in a workplace where practical jokes are the norm, you can always fill them with grease and leave them laying around to see if a coworker "borrows" them.......
The real beauty of a cheap HF tool is that after it fails, you can throw it as far as you can without any financial remorse.
grin Now I'm sorry I don't work in a shop. That's just diabolical. wink
Amen to that.
That's almost as sneaky as stretching a piece of Saran Wrap over a toilet bowl!
I'm going to agree with Denny on this one. I don't even recall the last thing I bought at HF. I have better luck with Menards and Tractor Supply. The store brand seem to be better quality than HF and price is about the same. Tractor supply seems to have really good deals on clearance items, especially after they re-fit the stores for the next season.
The last automotive tools I purchased, (a ball joint press and power steering puller), I purchased from Amazon. The quality was HF equivalent or even better and price was better. Not to mention, it showed up on my doorstep in a couple days.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Big Bolt Forum Moderator
I bought some of their 500watt halogen bulbs for my work light. GARBAGE. They work for an hour or two and then burn out!
Mike
I always use 3M for abrasives...
just-a-hacker
'49 3100 before '99
Moderated by  MNSmith
