| | | Forums66 Topics128,104 Posts1,056,201 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 109 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 109 | Any Idea im putting in wiper base that goes through the cowl but how do i separate the arms that go under the dash and the top that goes out side is it that one tiny flat head set screw? | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | I have installed many wiper vacuum motors, transmission arms, wiper arms/blades, and on/off switches on 47-53 trucks and I have no idea what you are referring to with "wiper base", "arms", and "tiny flat head screw". If you could break down your questions into each component, and describe what each piece does, looks like, and where it is located, it will be easier to assist you. Carl
| | | | | Joined: Nov 2012 Posts: 109 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 109 | Sorry that was a terrible explanation. ok the out side chrome piece that the actual wiper arms attach to it has the linkage hooked up to it that connects to the wiper motor. How do i separate the linkage to the outside chrome base? | | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | It is not easy to do. Some careful grinding with a Dremmel. Once you have it apart, you will need to weld it back together. What is your reason for taking it apart? Carl
| | | | | Joined: Nov 2012 Posts: 109 Shop Shark | | Shop Shark Joined: Nov 2012 Posts: 109 | Ok reason for my stupidity was not paying much attention at all I grabbed the wiper tops and linkage for my 49 chevy styleline I happen to really take the time to look at it today But thank you for helping Carl
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | Glad I could help you to regain full consciousness.  Carl
