1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Trying to find information for an upcoming project. The PO has put a Chevy small block and 6 speed trans W/PTO into an early '49 2 ton COE! Here's what I'm trying to identify: It is a small block couldn't find any obvious block numbers, Chevy red/orange, 2bbl carb, dist in the rear with little door to adjust dwell. Right side exhaust manifold has the alt/gen mount cast onto it. Obviously came out of a truck because the trans came with it. 6 speed with PTO, shift pattern - reverse toward driver and back 1-6 in a double H. The rear engine mounts are on the bellhousing and appear to bolt right into the original frame cross member. Because the engine is shorter than the inline 6, the front mount (single in the center) is mounted on a piece of heavy channel behind the front cross member. This allows the engine to sit a little lower.
I think the 6 speed is the clue since I've found very few references to a Chevy 6 speed.
All the info and pics are in Big Bolts: thread - Maybe CEO project. | | | | | Joined: Dec 2006 Posts: 206 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 206 | On the back of the engine where it bolts to then bell there will be cast numbers | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy again Jim Sears, I seriously doubt that you have a six speed transmission there, five speeds were the norm back in the day. A five speed will have seven different gates, neutral, first/low, second, third, forth, fifth, and reverse, some transmissions shift patterns are laid out in a double "H" pattern and some have an "L" on each edge of a single "H", hope that helps. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Now that I think about it some more you might have a pretty late model (01-07?) GM only ZF 6 speed as used in medium duty trucks. I think the similar ZF 6 speed used in the GM pickups had integral bellhousing and the medium duty transmission was without bellhousing.
If it is, and before you do away with the transmission, I'd be interested.
Grigg
| | | | | Joined: May 2015 Posts: 11,002 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,002 | Now that I think about it some more you might have a pretty late model (01-07?) GM only ZF 6 speed as used in medium duty trucks. I think the similar ZF 6 speed used in the GM pickups had integral bellhousing and the medium duty transmission was without bellhousing.
Grigg From his description of the shift pattern it isn't a ZF-6 used in GM trucks. Ford put basically the same tranny in the Diesel Superduty trucks from 99 thru about 07 (maybe later). I have one of those and the shift pattern (going top to bottom and left to right) is R,L,1,2,3,4,OD, with OD hanging out to the right and away. I believe the GM equivalent used the same shift pattern. They also split vertically with a very short main section and front and rear covers bolting to it. The housing is aluminum.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | It will be very interesting to see what it is when I get to the project. It definitely has a spring loaded reverse gate that's toward the driver and back. I watched the client as he shifted through the forward gears several times, he counted 6 and it sure looked like he was finding them. Thanks guys | | |
