4 members (Guitplayer, Wally / Montana, 46 Texaco, 1 invisible), 59 guests, and 3 robots.
Topics128,264
Posts1,058,357
Members48,485
#1182871 09/16/2016 7:43 AM
SM420 transmission 1:1 final with 3:38.1 ring pinion 27" dia. Tires 1954 3100 PU. At 35mph on speedometer actual speed 40 mph about 5/6 mph difference. We need a ratio adapter for the transmission any suggestions or model numbers. Don't want to fool around with the speedometer itself a ratio adapter would be an easy fix and easy to remove.
Thanks!
Some people just use a GPS for their new and accurate Speedometer.
Jim Carter used to provide ratio adapters - he might still do that.
The Speedometer Shop is where I have obtained ratio adapters - they seem to be out of business.
Bob's Speedometer Shop supposedly makes them ($!50).
A Google search of "speedometer ratio adapter" gives these results.
Maybe someone who has obtained one in the last year will post information?
Would a one tooth change in the driven gear from the tranny, less than $15, not work?
You will need to check it at 60 mph for the best reading. Most all of the cable driven speedometer are calibrated at 60 mph, 1000 rpm of the cable is 60 miles per hour.
Here is a good link to really check yours.
https://www.hotrodhotline.com/calibrating-speedometer#.V9vrrjtT5Tc
Trans gears are a easy to change, but you still need to know how far off it is at 60.
I got a ratio adapter custom made from PATC Transmission Center in Louisiana. I figured out my percentage with a GPS and multiple test drives and then called them up and it works great
Crusing in the Passing Lane
I'm sure there is a speedo shop in Redding, even Sacto where
you can get an adapter, even look for one in a wrecking yard, speedo shop should be able to fix you up.
Ed
I wrote to Novak transmission and gave them my numbers. Turns out I'm about 11% off the mph. They directed me to an ebay supplier for said ratio adapter. Novak excels at after sale customer service.
Thanks to you all!
I affirm "delwrench"s comments! Works great on my 1946 Chevrolet truck original speedo.
