| | | Forums66 Topics128,042 Posts1,055,518 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | I spent a lovely 2 hours Sunday evening (Did not watch Saints, they make me crazy) inserting the vent glass only to remove it because I did not realize that the door window regulator has to be inserted first.
The GMC manual has a picture that shows that the entire assembly has to be inserted together, that seems just a bit nuts and a great way to scratch up your paint. H as anyone installed the main window glass in the doors while the vent window assembly is already in place.
Any pointers you can lend would help.
Thanks Jake
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | I struggled for a while until a realized that the vent window brace (with vent window) has to be turned 90 degrees in a little divot in the door frame to clear the window and the top of the door. It was not graceful and not intuitive. It helped to move the window up and down some to settle everything in. So yes the window and regulator go first and yes a scratch (in my case) was inevitable. I should have used more tape. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Ok Thanks, I had to reorder the accordion felt, as I screwed them up getting them out. I'll try to do a pic/install thread | | |
