5 members (Rich'sToys, J Lucas, Charles in CA, Stovebolt48, 1 invisible), 95 guests, and 1 robot.
Topics128,151
Posts1,056,994
Members48,460
Hello. Would anyone know what the min and maximum tolerance or clearance of the throttle shaft and the body should be. Thank you
Carburetion specialist
Original was 0.004~0.006.
An additional 0.003 is acceptable.
If the clearance doesn't exceed 0.009, you will be OK.
Jon.
The Carburetor Shop
Hello carbking thank you very much for the information. I needed to know that because I have just purchase a rebuilt carb from a "carb rebulder" and when I got it home and looking at it I noticed it seemed to have more play in the throttle shaft than the carb I was replacing. So I mounted it in my mill and measured the shaft movement with a dial indicator, the rebuilt had .012 and my original had .007. Now I have something to go to bat with. Kevin
