| | | Forums66 Topics128,193 Posts1,057,255 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2016 Posts: 102 | I've installed a new set of stainless steel brake lines that I purchased from Inline Tube. I'm using the original T-Blocks on the truck and everything fits just fine with the lines and the T-Blocks. However, I also got 3 New Hoses (2 front wheels and 1 rear axle) that I'm having some trouble. The hoses connect to the brake cylinders just fine, but the Female end that is supposed to connect the the steel lines is way too big. It appears to be 1/2 inch. I believe all the steel lines I have are 3/8? Does anyone know where I could get a good set of the 3 Hoses (2 Front & 1 Rear) that have the correct Female connection to my steel lines? | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | I would contact Inline Tube and ask them if they should have sent adapters. If they market the product to fit your specific application then it should fit! Of course that also applies to whoever you got the hoses from.
Ed
| | | | | Joined: Jun 2016 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2016 Posts: 102 | Excellent! The OReilly says End 2 Female is 3/8, believe that is exactly what i'm needing. My sincerest Thanks!
| | | | | Joined: Jun 2016 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2016 Posts: 102 | Rec'd the O'Reilly hoses in the mail today-they were a perfect fit. So glad I came to the forum with the question, appreciate the tip Bart! | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Good news. Glad it worked.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
