Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (1955 1 Series, Otto Skorzeny), 103 guests, and 5 robots.
Topics128,283
Posts1,058,505
Members48,490
#1182013 09/10/2016 11:15 PM
I search the forum and could not find an answer. I have a 3/4 ton with title that has been painted fiberglass running boards and has small block in it. I can't seem to find the vin plate on the truck anywhere. Did it have one? If so, where? Any help would be appreciated. Thanks.
Open the right-hand side of the hood. On the cowl there should be a tag with the body number and GVW. It is attached with a couple of clutch head screws. After 70 years, some of them are hard to read.
That is excellent. Thanks much!!!!! Are you able to post a photo of one?
RJD Offline
here is one I found with a google search for "1946 chevy truck cowl tag"
google image
Thanks!
Let me know if you want a closeup. I will take one of mine if you need it. By the way they do make reproductions of these tags. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Dave. That would be great. I got an after market one that I will have engraved and I'd like to be 100% sure where to put it.
Ok, give me a couple of days. Dave
1941 Chevy
