| | | Forums66 Topics128,179 Posts1,057,157 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | An internet friend of mine has a 1954 Chevy 235 engine
from a passenger car with power glide. The engine block
# is 3835911 with a date casting of D284 , which
translates to : April 28, 1954.
His plan is to have the hydraulic camshaft reground to
1954 solid lifter specs & then run solid lifters.
Is this possible ?
Need some in depth opinions of his plan.
Thank You, George '54 3600 | | | | | Joined: Feb 2004 Posts: 29,875 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,875 | Why not just buy a new cam with the appropriate lifters? Regrinding a cam reduces the diameter of the base circle of the lobes and makes it difficult to get a good adjustment because the adjusting screws on the rocker arms have to be turned in too far. I've seen some rockers with the lock nuts on the underside to accomplish a deep enough adjustment. Changing the grind from hydraulic to solid would involve taking a lot of material off the cam lobes.
While he's at it, does he intend to install acetylene gas headlights, a magneto, and a hand crank for starting? Might as well take a giant leap backwards with the rest of the vehicle! Jerry
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | It will be cheaper just to buy a new cam and a set of lifters,when I built my 235 power glide the cam was junk and I put in a new hyd cam and lifters.
Pete | | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | Why? I have over 100 thousand miles on a rebuilt '56 hydraulic.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
