9 members (JoergK., klhansen, Hotrod Lincoln, Stovebolt48, 1955 1 Series, Bill Hanlon, fonz8261, latroca52, 1 invisible),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,195 Posts1,057,373 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | I am in the middle of a frame off on my 54 GMC 5-Window 1/2-ton and I want to paint the bottom of my cab when I pull the cab off the frame. Everyting is off the cab except the Windshield and rear glass. Will I hurt the cab or glass if I roll it onto the firewall or back while I work on the bottom? Is one position better than the other? Thanks.
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
| | | | | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | Cujo8,
My cab is not the same as yours, 1940, but I had problems rolling it on the back because of the very back edge of the cab is just sheet metal and can't hold the weight of the cab. Check yours out and look to see if that edge can hold up. Otherwise roll to the front and lie it down on the firewall.
Bill Schickling | | | | | | Anonymous Unregistered | | Anonymous Unregistered | On my 54 I tipped it onto the firewall. The back panel is not strong enough to support the weight of the cab in my opinion. As for painting the bottom of the cab I used Zero Rust. If you are doing a show truck then painting it like the topside would work but you will have fun keeping it clean. | | | | | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | | | | | | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Houston54, Did you remove the glass when you rolled yours over onto the firewall? I do not wish to remove the glass on my truck, since the truck was just painted and the glass was reinstalled with new gaskets just before I bought the truck. The logistics of trying to do a frame off on a freshly painted truck is a real PITA.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | If you are careful I do not see why you could not leave the windshield in. If you do make a mistake it will cost you about $225 to fix it though. I did not have a windshield in my at the time I was working my cab. Still waiting on the SWMBO to give me the green light for that purchase. I have put it on my Christmas list though. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jul 2006 Posts: 232 New Guy | | New Guy Joined: Jul 2006 Posts: 232 | I also rolled my 39 on to the firewall. Worked great. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I was able to tip mine backwards without any problem. I put a 4 x 4 sheet of plywood against the back of the cab and the other end rested on the shock mounts. Lay down some blankets and then lift the firewall with a come along and tip it. If you tip it on the firewall you have to completly remove it from the frame. I tipped back, did the rear floor and then cut along the seat line almost thru. Then I tipped it back down to use the frame as a jig to relace front floorpans. (Not relevant to you though)I second Houston on the use of Zero-rust and then I put undercoating on top of that. http://image44.webshots.com/44/9/63/2/377796302iiUZdN_ph.jpg
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | Stea, When you rolled yours onto the firewall, did you have your glass installed in your cab?
