1 members (baldeagle),
106
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 65 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 65 | Have 42, 1.5 ton.. Experiencing a grind from neutral to low or 2nd gear.. Also have the same from neutral to reverse. If i hold the clutch in for about 15-20 seconds the grind is still kind of present, but less noticeable.. I can not recall if it always did this or if its normal. Double clutching from 2-3, and 3-4 works well without grinding. Thoughts ?
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | I have a 4 speed in my 42 1/2 ton and it does the same thing. It has done that for 15+ years without issue. I assumed it is because shafts are still spinning after you push the clutch in.
When coming to a stop, I have learned to drop the tranny into second (my usual starting gear) when I drop below 5 mph. The tranny and engine at idle are synchronized at that speed and then you don't get the gear clash.
Kent
| | | | | Joined: Mar 2011 Posts: 107 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 107 | Mine will do the same thing, especially when everything is up to operating temp and the oil is thinner in the transmission. It doesn't take much drag through from the moving parts to make the disengaged clutch disk want to follow along with the movement when everything is turning free, and with no synchronizers there are only gear teeth to bump along until you pull it into mesh. However, with that said, mine will generally stay mostly stopped if you stop by holding the clutch and leaving the transmission in gear while stopping and then find neutral without lifting the clutch. Once stopped, you can shift to another gear generally without any clashing, except on occasion the high points on the teeth are lined up and you'll have to bump the clutch out slightly or just wait a moment for the teeth to creep past so they will mesh. I'm spoiled with the aux transmission, as I can pop it into neutral, and since there is nothing then connected to the output of the main transmission, it will slip into gear without any major clashing pretty quickly, and then the little bit of extra drag from the intermediate shaft and gears in the aux transmission spinning will slow everything down to a stop much quicker while keeping the clutch depressed. Although if your not patient, you can still get the aux into gear too soon with a satisfying clunk and a small hop forward in the truck....
The key is patience, sometimes a lot of it. The problem described is why many large trucks have a clutch brake that activates when the clutch pedal is fully depressed.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Also, make sure the clutch is fully releasing.
Ed
