2 members (2-Ton, Forty9),
108
Mod | | | Forums66 Topics128,128 Posts1,056,685 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Trying to install the electric wiper kit into a 1950 3100.
Mounting it was easy (considering you have to be a gymnast to work under the dash.
What I having trouble is adjusting the arms so that it give a fairly full swipe at the windshield.
I have loosened the allen head screws and adjusted the cross bar for the transmission arms to attach to, but don't get a full swing. 3/4 maybe is all I'm getting.
anyone have any tips or is that about it?
Thanks | | | | | Joined: Mar 2010 Posts: 10,296 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,296 | Try placing the lever on the motor in the straight up position, then put the wider arms on the knurled knobs so that they are also in the straight up position. Carl
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Okay, I've been trying to go from a parked position with the motor. I'll give that a try. | | | | | Joined: Mar 2010 Posts: 10,296 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,296 | That is how you set up the vacuum wiper setup. I am only guessing that the electric ones would be similar.
| | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | This was a two solid week project for me. I can't count the number of times I pulled it out and put it back in. I have no great advice as it was purely trial and error. The kit could have had much better directions.
Good luck... | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Thanks, it's working as good as it's going to I think. I started out having little movement at the wipers at all.
I've turned that little bar every direction I can think of and finally got 3/4 of the window wiped. Maybe that's all this one will do.
Acts like the lever the transmission arms hooks to with the spring clip is a shy short and not pulling the arms enough.
Since it has new glass on it I've been using clothes pins on the nub sticking through the cowl to see how much swing it had rather than running the wipers on the windshield.
I'm gonna ask the manufacturer if they have any tips.
| | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Sorry I can't help with a cure Roy but I noticed a similar problem on the Art Morrison 'Farm truck'. The o/a sweep was dreadful.... Sorry for the long video but you'll notice it in this @ 2 minutes 50 seconds. That frankly would drive me nuts! 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Yes sir. The sweep of the wipers in the video is the same as I have on the old 50 I've been working on.
I like for the wipers to pull down close to the windshield gasket when parked, and go almost to the side of the gasket when running.
The last two trucks I've put the electric wiper kits on has had this same problem. I can't get a full sweep.
Thanks, video makes me feel it may not be what I'm doing wrong after all. | | | | | Joined: Aug 2010 Posts: 70 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 70 | Have you used the same motor setup on the last two trucks as well as this one? Have you seen someone else's setup that works better? What brand of motor are we talking about? | | | | | Joined: Jul 2014 Posts: 186 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 186 | Yes sir. The sweep of the wipers in the video is the same as I have on the old 50 I've been working on.
Thanks, video makes me feel it may not be what I'm doing wrong after all. Ditto | | | | | Joined: Jan 2016 Posts: 1,101 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 1,101 | I installed on in my 54 and at best the wiper swings from about 2:00 o'clock (parked) to about 11:00 o'clock on the full left swing.
| | | | | Joined: Mar 2010 Posts: 10,296 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,296 | Is the arm on the electric motor the same length as the one on the original vacuum motor? If not, would matching the length of this arm with the original length solve the problem? Are these electric motors supposed to auto-park when off? We can fix anything. We are Bolters after all. Carl
| | | | | Joined: May 2015 Posts: 11,113 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,113 | What Carl said. A longer arm on the motor will increase the wiper stroke angle. Pretty easy fix. You might even consider building an adjustable length arm so you can fine-tune the stroke.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | No original vacuum motor to compare the length of the lever on it, but that is what the problem is it seems. Or the sweep of the electic motor is not the same as the vacuum, but again no original to check it by. Was no vacuum motor in the truck.
And yes, the electric motor has auto park when turned off it returns to the down position.
The owner seems happy it works, so if he complains later I'll see about making the lever arms longer on the motor.
Thanks | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Put one in the 52 1/2 ton after the Vacuum wiper motor failed. At first I had a good sweep on the passenger side and a narrow one on the driver side. After adjusting and looking at every bit in the system..I found an "indexing" adjustment. That seemed to fix the issue. A combination of the arm position and the motor position. Mine had a nut to clamp the motor to the bracket and a screw in a slot on the bracket.Fussed with both until the "park" position was straight up(in the truck) that seemed to do the trick. Getting under the dash was a whole 'nuther kind of torment. Good luck with yours.
Steve H
| | | | | Joined: Aug 2016 Posts: 146 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 146 | What wiper motor conversion are you guys using? I recently installed one (from LMC) and it sweeps almost too far - all the way from the lower rubber to almost hitting the side rubber. It required careful adjustment to prevent contacting either. There was an adjustment that Steve refers to (above) but I just left it as it was.
BTW, ditto on the "in-and-out" a dozen times and being a contortionist under the dash! | | | | | Joined: Mar 2010 Posts: 10,296 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,296 | Put a wide board on a saw horse or similar support at the same level as the floor board and run the board into the cab. I put a moving blanket on the board. The first time I did this, I thought I was going to fall asleep it was so comfortable!
| | | | | Joined: Aug 2016 Posts: 146 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 146 | GREAT idea! But why didn't you tell me BEFORE I wracked my shoulder, head and hip crawling on the edge of the door sill? ;-) | | | | | Joined: Oct 2005 Posts: 4,258 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,258 | | | | | | Joined: May 2015 Posts: 11,113 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,113 | Good idea. Here's one that's nearly a must for working in the engine comnpartment of full size pickups. Topside CreeperWe don't need that on our AD trucks, because of the nice wide fenders, and no lumps that hit strategic body parts.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Aug 2016 Posts: 146 Shop Shark | | Shop Shark Joined: Aug 2016 Posts: 146 | At first I had a good sweep on the passenger side and a narrow one on the driver side. After adjusting and looking at every bit in the system..I found an "indexing" adjustment. That seemed to fix the issue.
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Don't worry about hijacking it. maybe someone will eventually find an easy adjustment or tell us a cure to get the full sweep.
