1 members (1 invisible),
105
Mod | | | Forums66 Topics128,089 Posts1,056,440 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Is the reverse lock out lever only to be found on the floor shift lever on the 4 speed trans and not the 3 speed floor shift lever trans?
What years used that reverse lock out lever? Jeffrey | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Reverse lock out was used up to 1947 on 4 speeds.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Dave, am I correct to assume that if there is no reverse lock out lever then it is always a 3 speed prior to 1947? Jeffrey
| | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | There is no reverse lock out lever on my 3-speed floor shift trans in my 39.
Rick
1939 Chevrolet Stake Truck
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | No three speed had a reverse lock out.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Thank you Rick and Dave. Jeffrey | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
