7 members (Gdads51, Lightholder's Dad, ShopRag, Hotrod Lincoln, sudsyz, Chip O, 1 invisible), 77 guests, and 0 robots.
Topics128,210
Posts1,057,456
Members48,471
I'm working away on my truck, and it looks like the shaft is pretty pitted up. I have another one from a different truck, but whoever took it out pounded it out from the frame side and beat up the threaded end. Does anyone out there sell replacements? I've looked at a couple vendors, but no luck. Advice?
Thanks!
You may be able to fix the threads with a thread repair file. It is a many-sided file with different pitches on each side. It allows you to work on 3-4 threads at a time, working around the circumference of the bolt.
Carl
' Offline
The Brake / Clutch shaft is not being reproduced.
This is a rare part & very hard to find NOS.
I bought this one GM NOS for my 1954 in 2010.
photo@photobucket
http://i669.photobucket.com/albums/...rake_Shaft_3683044_b%202_zpsm4knzgk1.jpg
GM # 0.833 - GM # 3683044
is available GM NOS
NOS Parts Source
Olathe, Kansas
phone: 913-220-5746
NOS Parts Source has ( 1 ) GM # 3683044 in stock
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
The guy mushroomed the end of the shaft pretty bad, but I do have a friend with the tap & die stuff around, so we will give it a try. Thanks for a great lead, George! I had a feeling it wasn't out there in the reproduction world.
Thanks, Guys!!
' Offline
A rare part shows up on ebay once in a blue moon.
There is currently a Brake & Clutch Shaft
on ebay. I looks like it needs a good soaking in Evapo
Rust. Never the less it's GM NOS. It might be worth it
to take a chance.
photo@photobucket
http://i669.photobucket.com/albums/...gm%203683044/3683044%202_zpsnyi56ex2.jpg
ebay seller incorrectly states, it's only for a DD
model truck.
ebay link:
http://r.ebay.com/GQuXfw
Here's the 1952 Master Parts Manual page.
http://i669.photobucket.com/albums/...m%203683044/GM%203683044_zpsi1v9enko.png
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
