| | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 63 Member | | Member Joined: Feb 2004 Posts: 63 | Hello everyone, The 53 and myself are not seeing things eye to eye today.Hear is whats going on.I am deep in the middle of the floor board-cowel-kickpanel-rockerpanel patch panel fiasco,assembling it all with sheet metal screws befor welding, seems the 53 thinks it looks better with no doors.They wont close right I have been dooing a little hinge bending with not a lot of luck.I would be very greatful if a couple of you guys would go slap a tape measure on your rocker panels and give me the measurement between the door post also what is the average size of the gap around the door? Thanks Aaron :rolleyes: | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You just found the reason why you brace the door frames before doing this work. Your cab has flexed.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Aaron, I recommend you measure the width of your doors at both the upper and lower hinge points and then check the opening width. You need 3/16" minimum on each side or 3/8" overall. If the opening is not enough remove some of the screws and put a bottle jack and blocks between the pillars and open it up a bit. I tacked angle iron braces from the top of the seat base to the inner firewall and it helped mine to keep shape. I also cut 2 small angle iron pc's to hold the opening in place while I welded. My door gap turned out great all around and this was my first time at this type of surgery/welding. Here's some pic's of how I did mine. Good luck. http://community.webshots.com/album/377692314ehfoan Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
